PCV Valve
7207 Views 8 Replies 5 Participants Last post by  theheder
Is the PCV valve located on the drivers side head at the rear? How do you remove it if needs replacement/testing?
1 - 9 of 9 Posts
nothing to replace/test on our trucks.
there is a metered orafice in the drivers side cover, that consists of the pcv system.
not like the old stuff that had a check valve style set up.
Is it anything that should be replaced during regular maintenance, just like a PCV valve?
nothing to replace, remove, repair, or check during any services...
as long as the hose is connected... its doing its job.
Yeah, thanks Greg! I was sitting there staring at it during my last oil change trying to tug on it to see if it would come out. I was about to grab the pliers and thought I better ask first. ;)
yeah, its pressed into the cover, and set with an epoxy of some sort.
Mine seems stuck any suggestions
Holy necro thread bump
Leave it alone
1 - 9 of 9 Posts
