1 - 8 of 8 Posts
=ЯΛWSSUM=
:dunno: not yet. Did water get inbetween the connections or something?
07 TrailblazerSS
9 X out of 10 when that happens to those harnesses its because the fan patch wasn't done correctly. If the fan patch isn't done properly it will pulse the fan. Load will go thru the roof and it will burn up at the relay first. It usually welds the relay together to. Send your patched file to [email protected] and we will make sure it was done properly. The other time I see that and its pretty rare is when you have a bad fan motor
1 - 8 of 8 Posts
