1 - 7 of 7 Posts
I just picked up a efan kit for a friend of his 06 ss. I had pcmofnc tune the ecm/tcm as well as add the patch( assuming they did).
my issue is the fans work but they run constantly the moment I connect the battery with the key in my hand. I double checked that the pin is seated properly in pin 56 on the blue connector. in the trouble shoot it tells me there should be a jumper installed for 05/06 model years which it states is in the kit along with the instructions. Neither of which came with the kit. NO instructions and NO jumper. I tried looking up instructions on the site but can't find it anywhere. I need this out of my garage. any help is appreciated, thanks
Paul
Both fans?
Is your ac on?
nothing was on due the keys being in my pocket. I would only imagine it has to do with the jumper not being connected but I don't know where to put it. I can make a jumper wire but I'm kinda high and dry without instructions. I checked it to my 06 tbss but it has a much older harness kit from pcmforless. Mine didn't require a pin being installed into the pcm harness.
thanks LS2Pwrd, I'll check my email.
Reading fails me sometimes
the jumper wire fixed it, thanks!
TrailblazerSS 3SS
Yeah have to pull relay and put a jumper in.
Good Deal....
1 - 7 of 7 Posts
