1 - 13 of 13 Posts
06 AWD SS
Need to get an alignment on my truck that's on 22's and dropped using just the struts and want to know what the parameters are for the camber angles. Will they be able to figure that out at Firestone?
Not sure if I'd trust a chain place... if you go somewhere with a relatively modern rack they should be able to get it right, mine was done with laser levels and all sorts of fancy stuff.
I would think that you would need to talk with Tony and get the modified upper DJM A arms to be able to align the truck?
07 TBSS 1SS AWD
you do not need to buy arms every time.
mine is and has been lowered since nearly new with no issues and stock arms...
mike.. if you are having a problem getting the truck aligned call the goodyear i told you about.. they NEVER have a problem aligning my truck.. and have a staff that are more competant than just doing what the computer tells them to do.
you should NOT need arms your truck is no lower than mine or tims.
I had no issue at all when I lowered the front 2" on 22" I have Scotts collars and DJM a-arms.
2006 white 2wd
It all depends on how much camber you want. I personally want zero camber so the upper control arms was a must. Make sure to get a printout of your before and after specs.
Administrator
are you using
0
or
8
or
16
MM spacer on the truck?
with 8mm spacer or less ive had issues getting them to align its a hit or miss but no spacers didnt align and the upper balljoint angle is wayyyyy off.
if you have 16mm spacer in there (which is like 1/2 inch of drop) you will align fine.
06 AWD SS
Discussion Starter · #9 ·
16mm and I just got it back, aligned perfectly. Thanks for the help tho.:cheers1:
TBSS
Fuckiing diddo, no need for arms unless you are going stupid low which I will be this winter on a set on one off arms. Gigitty! AWD on top of it.
BTW, your truck loved me compaired to Mikes.
06 AWD SS
oooohhhhhh you broke it:rofl:
1 - 13 of 13 Posts
