1 - 4 of 4 Posts
07 TrailblazerSS 2WD
It has 4 or 5 clips that break very easily. If you don't have to remove it, then don't. The piece is not replaceable, with the exception of buying the entire mirror assembly. IF you are going to pull it off you should have a plastic welder handy or a box of Q-bond to get the clips back on the mirror. I don't think there is a way to pull it off without breaking the clips. I've learned the hard way and now I have my drivers side held on with double sided tape.
1 - 4 of 4 Posts
