1 - 9 of 9 Posts
TrailblazerSS 3SS
P0496 emissions system
finally got around on fixing this problem. i ordered the parts through Greg( two-tons-of-fun). no more CEL :coolthumb:
part # for Purge solenoid GM- 12597567, ACDelco #-214-1680
part # for vent solenoid GM- 25950499, ACDelco #- 25950499
pics of there location
purge solenoid
Vent solenoid
i hope this helps someone.
Reactions: 1SickSS
TrailblazerSS 3SS
Discussion Starter #2
sorry, title should read P0496 emissions system. can a mode fix it please.:biggrin2:
08 Granite AWD
ok rounding out this thread with some useful data
the part number of the solenoid by the intake in my car above, smaller than the current version that superseded it (ac-delco 214-1680, or gm 12597567 as mentioned)
the new one was closed when i blew thru it, and it opened when i gave it power... so considering the one removed was open both with and without power.. i assume that it is case closed on this situation, and i would pop this sucker off and blow thru it (unplugged) before doing any more head scratching.. i bet its very common culprit.
2007 Silver 3SS
Did you have to drop the tank or remove any shielding to gain access to the valve?
2008 Black TBSS
1 - 9 of 9 Posts
