1 - 2 of 2 Posts
Sold
transmission shifts rough first gear wont shift to second help
P0707: Transmission Range Sensor Circuit Low Input DTC Trouble Code
If you see a P0707 OBD2 trouble code, it means that the transmission range sensor/neutral safety switch/park/neutral switch is not responding to the ECM signal with enough voltage. This DTC is often accompanied by other trouble codes, and it could mean there is an issue with the transmission range sensor or the wiring.
1 - 2 of 2 Posts
