1 - 10 of 10 Posts
stupid white guy
As title states, is this okay? Done right of course, will it be okay?
I know they make extensions and all, but I can't wait that long.
They're not fiber optic are they?
The Lurker
TrailblazerSS 06
Cut away!! (nicely) Lol
07 TrailblazerSS Imp
Just pull the pass side 4 wires out of the loom and detach the harness from the back of the block and pull those wires out all the way to the front so you can route them directly to the O2 sensor. Then detach and slide the harness at the front of the intake and slide it back 6-8" and you will be able to hook up the driver side O2 sensor.
TBLT
snip, strip, solder, heat shrink.
you shouldnt have a problem, i had to extend mine for my longtubes
stupid white guy
DONE.
And it worked. Looks nice and clean too.
Had to have cats added to my Pacesetter Y-pipe, it's all done and looks awesome now.
stupid white guy
Discussion Starter · #9 · (Edited)
Truck is in the shop, I can get pics later. I used some Magnaflow spun cats, they are 8" long, and straight through basically. One for left bank was installed in straight run in front of crossmember, so it goes left to right. The right side was between collector and Y-Pipe merge. It took a lot of cutting/welding, but they fit. Quieted it down a little too. Maybe the neighbors will quit bitching when I leave for work at 330 AM.
Here's the cats:
http://www.jegs.com/i/Magnaflow/642/59959/10002/-1
1 - 10 of 10 Posts
