1 - 8 of 8 Posts
06 Trailblazer SS
I have two choices not sure which is better and or easier to install.
I have the SLP Pump and Double Roller set.
SLP Oil Pump
SLP Timing Chain
I also have a Texas Speed Ported LS6 Pump and new LS2 Chain set.
LS2 Timing Chain
TSP Ported LS6 Oil Pump
I plan to use the ls6 pump and ls2 chain because I don't want to worry about any clearance issues with the front cover from the double roller.
Any one using the slp setup?
Please don't reply with get a melling pump... Not going to happen.
Just looking to see if anyone is using the double roller from slp without issues.
I do believe the slp oil pump is made to use the slp double roller.
I'm just not sure if the cover needs to be modded.
I got my pump from slp. I bought a new stock timing chain I would just call slp and tell them what your wanting to do. There good ppl there.
06 Trailblazer SS
You run the slp pump but just a regular ls2 chain.
Did the slp pump boost oil pressure any?
I already have the two pumps and two chains I listed.
I'm either going all slp or the ported and single.
Either way I think I'll be ok.
Whatever is left goes on my iron 402.
Which came real close to going in the trailblazer.
I really just wanted to see if anyone was running a slp double roller chain.
I have the lingenfelter timing chain set and melling oil pump on my 403.
=ЯΛWSSUM=
I have the melling oil piump.. is it weak or bad or somethng.?:dunno:
The melling oil pumps are good from my understanding, works good on my motor.
06 Trailblazer SS
LOL
There is nothing thing wrong with the mellings oil pump.
They probably really are the best pumps.
They must be because they are mentioned in almost every oil pump thread on this forum.
I just have two brand new oil pumps sitting here already.
I put that in the original post because I know how these threads go.
Ask a question about A and B and get a half dozen replys about C or in this case M...
I asked if anyone has used the SLP oil pump and the SLP double roller chain without issues.
I'm already set on using the ported LS6 pump that I have and a new LS2 chain.
:cheers1:
1 - 8 of 8 Posts
