1 - 20 of 109 Posts
MOST HATED
I am looking to compile a nice organized list of part weights. Post anything you have weighed ACCURATELY please. Balancing a 16lbs bowling ball on one side of your kid's teeter totter with your passenger seat on the other end is not what I am looking for. I will continue to update the first post as parts are added.
1 Gallon of gas: 6.175lbs
AWD transfer case: 60lbs 7oz
Front & rear AWD driveshafts: 27lbs 5.75oz
Front CV axle: 18lbs .75oz
Front Differential, bearing support and shaft: 50lbs 11.5oz
2wd 4l70, dry no converter: 155lbs
6 spoke 16" alloy spare wheel: 17lbs 1.25oz
Rear carpet: 28lbs 5.75oz
AC system (minus evaporator): 31lbs 6.75oz
Rear air bag crossmember: 20lbs .75oz
Stock mechanical fan: 16lbs
Stock muffler: 21 lbs
Driver seat: 66.8lbs
Pass seat: 57.2lbs
wide seat bottom: 16.8lbs
narrow seat bottom: 14.3lbs
wide seat back: 51.6lbs
narrow seat back: 28.4lbs
hitch & bolts: 61lbs
washer tank, and pumps: 3.1lbs
spare tire lift: 4.6lbs
spare tire and wheel (39lbs of air): 60.2lbs
misc hardware,clips, and seat track covers: 3.9lbs
engine cover, and underhood mat: 3.6lb
floor mats(ft and rear): 1.9lbs
rear floor cover(lid): 4.6lbs
jackk and tools: 6.9lbs
drivers side rear panel(lower with lid): 1.6lbs
pass side rear panel(lower with lid): 1.2lbs
drivers and pass upper rear panel(creme): .9lbs
onstar computer and cover: 1.8lbs
rear seat belts: 1.3lbs
2-steel dash brackets: 4.6(total)lbs
small 90* tab on frame(under balancer): .8lbs
front core support tubes (both):1.6lbs
front sway bar and hardware: 17lbs
air compressor:10 lbs
stock ss front brake rotor: 21 lbs
stock ss front brake caliper brackets and pads: 6 lbs
TB LT front brake rotor: 16 lbs
TB LT front brake caliper brackets and pads: 5 lbs
nitto 555r 245/45/17 tires: 23.62 pounds
nitto 555 245/45/17 tires: 25.62 pounds
stock battery: 36.8 pounds
braille battery: 21 pounds
rear hatch carpet: 3.04 pounds
rear hatch trap door: 4.80
air hose: 1.61 pounds
heat shield behind rear tire: .32 pounds
all floor mats: 4.49 pounds
drop hitch and rear bumper: 54.2 pounds
stock manifolds and stock y pipe: 56.8 pounds
AR 1 7/8 ceramic coated headers and y pipe with cats: 41.5 pounds
stock alloy wheels: 21.85 pounds
chrome envoy wheels are: 21.1 lbs
Stock 20" wheel with 1/2 worn goodyear rsa's: 57lbs
17" chrome envoy wheels with hoosier 245/45r17 dr's: 37lbs
Rear axle weight with no calipers or rotors, full of oil: 240lbs
MOST HATED
before or after chipotle?
MOST HATED
thanks, deleted the heavier one. I found it and added it all in to the above.
How in the world did you come up with all these weights?
Reactions: Crobarr6
MOST HATED
Discussion Starter · #11 ·
its true!
Reactions: SSmokinem
MOST HATED
Discussion Starter · #13 ·
bout tree fiddy
High and Tight!!!
You sir... are the man. STICKY!!!!!
2007 TrailBlazer SS
Pass seat: 57.2lbs
i don't think my truck has one of these. mine must be that much lighter.
Your not suppose to be sitting in it while its on the scale.
Actually find some of these weights interesting. Jared, are you still listening to tunes or is the radio, speakers and amp gone?
My neighbor was telling me about car manufacturers and weight reduction when he purchased a new mustang. He said, do you know you don't get a spare tire anymore, you get a pump and a can of fix a flat. I am sure there is more weight they could find that doesn't need to be in there as well. BTW, neighbor asked if they will include spare and the dealer said sure for $486.
MOST HATED
Discussion Starter · #20 ·
its the 16" spare from an older trailblazer. I have another thread about using them as drag wheels.
Why the fuck does the driver seat weigh more?
I got that weight from greg's list in another thread. Next time I pull mine, I'll toss it on the scale.
Full stereo is still in the truck. Onstar and xm bullshit is gone though.
1 - 20 of 109 Posts
