1 - 4 of 4 Posts
2007 Tbss
This is for a 2007 TBSS AWD, no other issues, all stock, truck runs great.
Anyone know what parts I can buy off Rocksuto that could potentially resolve these codes?
P0054 00
Heated Oxygen Sensor (H025) heater
resistance (bank, 1 sensor 2)
P0059 00
Heated Oxygen Sensor (H025) heater resistance (bank 2 sensor 1)
POOR0 00
Heated Oxygen Sensor (H02S) heater
resistance (bank 2 sensor 2)
P0455 00
Evaporative Emission (EVAP) system large leak.
P0442 00
Evaporative Emission (EVAP) system small leak detected
P0058 00
resistance (bank 1 sensor 1 )
Miles? Looks like a 4 02 sensors but check for leaks first. Just 2 weeks ago i had 0496 code and both primary 02 sensors code, secondary are turned off, replaced the evap purge solenoid only all codes gone.
2007 Tbss
About 150000. I guess I can start with the evap stuff. The O2 codes came after the evap was on for about a week
Exactly, fix the 2 codes sm and LG leak and the others should dissappear. Look for broken or cracked hoses, easiest was is with motor idling spray carb cleaner around all hoses and joints if the rpm fluctuates you found the leak.
1 - 4 of 4 Posts
