1 - 19 of 19 Posts
So I installed my HIDs while I was swapping motors (why not the front is off right).
My fogs work fine, but my headlights wont come on at all.
I have not installed the jettt harness yet, but figured the headlights should come on regardless.
Any thoughts?
Thanks,
Jeremiah
08 TBSS
Could be the ground.. Some of these kits need you to swap the 2 plugs that are really small and kind of round. A bad ground will cause them to flicker on real quick then right off.
Try flip flopping the hid plug into your factory light plug sounds like a polarity issue.
:iamwithstupid:
It is 180 degrees you can only go one way or flip it upside down to do the other. If the polarity isn't correct they won't fire.
+3 on the plug.
I will check the polarity when I get home.
They only connect 1 way so I didn't check...another lesson learned! My fogs had to be "hard wired" and no issue, so it probably is polarity-I didn't think of that, as I "assumed" it was correct since they had the propper plugs.
If its a DDM kit the bigger plug on the ballast can be plugged in either way, turn it around.
Im sure you have the red to red and the black to black on the actual bulb wiring.
'07 3SS AWD
How did you go about wiring your fogs? I'm going to put mine in next weekend.
Edit: And yeah, I made the mistake on that plug the first time as well. If you used a relay harness, check the ground as well.
Discussion Starter · #10 ·
Its all good...just flipped the plug and viola HID headlights!
The fogs I just slid the pins into the stock harness and put lots of electrical tape around them. Some one had posted the plug PN somewhere, I may do that someday.
Yeah DDM's little lock nub thing is opposite from our factory plug, but they work great. I put a thin zip tie between the wires on the plug and the other side of the ballast to make sure it doesn't come out.
everyone has that problem with the ddm ballasts lol
I know I did with my DDM. I ended up oulling out the plugs from the DDM harnes and reversing the wires so everything locking in place like it was designed to. Worked great.
The raptor kits from DDM have the plug-in on the ballast marked + and - so just make sure you put the plug to that so the red is + and black -.
1 - 19 of 19 Posts
