It’s all gears I got the kit from ct power train products
New Complete TransTec Overhaul Kit
Late Pump Wedge Type Outer Seal
Fiber Pan Gasket
All Paper Gaskets
All Rubber Seals
All Rubber O'rings
Metal Clad Pump Hard Seal
Metal Clad Tail Housing Hard Seal
Metal Clad Shift Shaft Seal
Teflon Sealing Ring Kit
Small Nylon Filter Screens
Misc. Small Seals Sub-kit
New Raybestos Tan Friction Lined Clutch Plates (Less 3-4 Plates)
(2) X Over-run
(5) X Forward
(4) X Reverse-input
(5) X Low-reverse
New Raybestos Zpak 3-4 Clutch Update Kit
New Steels Kit (Less 3-4 Steels & Pressure Plates) Non-kolene
(2) X Over-run
(5) X Forward
(4) X Reverse-input
(5) X Low-reverse
New Regular Size Carbon Band.
New Bushing Kit With Teflon Pump And Tail Bushing.
New Transmission Oil Filter For Regular Pan Or Deep Pan**.
New 3/4 Bonded Rubber Molded Piston.
New Over-run Bonded Rubber Molded Piston.
New Forward Bonded Rubber Molded Piston.
New TransGo 46-PLT-07 Valve Body Separator Plate (Replaces Bonded Plate) that’s what was replace and sunsell, servo, input drum and speed sensor
