1 - 13 of 13 Posts
3SS TBSS
Got my 1 piece FWI, SPAL fans, and all the accessories today and starting installing. I got the SPAL fans installed and wired up but didn't get instructions for the FWI. Anybody on here have some they can email/text to me? I was wanting to have them installed tonight.
I need instructions for the following:
1 piece FWI
Window washer tank
P-030007 (the two pin connected that goes into factory ecu connector for 07+ 3 relay kit)
Any and all help will be greatly appreciated. If no one has it tonight I'll just call PCMofNC tomorrow morning
NE TBSS
I dont have the directions but my advise is to drill the 4 inch hole for the FWI from the bottom up, If you do it from the top down it will not look like it's right. Double check and triple check everything from the bottom and the top before you actually drill the 4 inch hole. Good Luck.
Jim CHEVY6000TBSS is definitely the go to guy for the 1 piece FWI. I bet he has the instructions and template laminated.
Your best bet would be to email Kelly in the morning.
Jake is local to you. For a hose purchase, I bet he would come and help you. He has a multi piece kit from them, so it should be the same.....
I threw that template away. If you followed the one that was sent to me, you will drill right through the lower fender support bracket. But good try on your behalf.
Reactions: 08HEAVYVETTE
Awesome. I Pm'ed him. Thanks for the direction guys.
The latest instructions were emailed to you by a member that recently purchased this kit and installed it.
Good luck.
TrailblazerSS 3SS
Just emailed you the template Kelly sent me. I think I have the directions still as well for the washer tank and such,,,
1 - 13 of 13 Posts
