I could not find a solution searching...
While adjusting my sensors the other day i noticed that after a few adjustments the compressor did not kick on after commanding a height increase, it was working a few adjustments before and everything sounded ok. So i left it alone and the next morning going to work its bouncing bad and about bottomed out. I checked fuse, height sensor connections, and bag position is fine. I unhooked battery and also checked height sensor arms all ok. I do notice that the drivers side bag seems to have less air in it than the passenger side.
Also of note before I left work I turned on the compressor for filling up tires and whatnot in the back for a bit and the ride home was much improved even tho the height in back stayed about the same.
Any help appreciated. I hope its a :doh: situation as i dont have the extra loot for the springs at the moment.
