1 - 4 of 4 Posts
06 TrailblazerSS
Hello,
I just bought a TBSS again and it seems like it’s in limp mode when in Drive.
It is throwing these codes:
P0103 mass airflow sensor circuit high frequency
p0700 Tran control module requested MIL illumination
any ideas where to start? I tried disconnecting the battery and cleaning the MAF.
2008 Black TBSS
First, check the MAF wiring and connectors for wiring damage, loose connectors or corrosion.
P0700
06 TrailblazerSS
P0700
I took the maf out and cleaned it, checked it all and still same.
Bought a cheap maf from O’Reillys and still same
2008 Black TBSS
Sincerely doubt it's the MAF even without your checking. Make sure all the wires are securely seated in the connector without any corrosion. Then follow the wires back looking for cuts or frayed wires.
More help
1 - 4 of 4 Posts
