1 - 15 of 15 Posts
TBSS 3SS
so.....what happen?
07 2wd TBSS
so.....what happen?
just woke up and saw my truck leaning to the left and and checked everything out and noticed it was not holding air anymore so even with me being covered with the dealer i said screw it and changing out to the coils shock combo
Ride IMO is way much more better and I did the DJM shock/coil combo also sitting at 31.5 which is where I want it
What did the setup cost?
I should be getting my DJM set up in the mail tomorrow. Did you cut the bags I half or can you just pull them out if the jack up the truck far enough. Also light come on the dash cause the bags are not there? Just wondering
Hater
Duh
No light. And I wouldn't cut them if they're in good condition. You never know if you'll want them and you may be able to sell them.
07 2wd TBSS
Discussion Starter · #15 ·
no light and if the bags are no good you can cut the air line and whatever air is left in will come out after that turn or jerk the bags counter clockwise and they will loosen up and just pull them off and BAM your good!
1 - 15 of 15 Posts
