Ok,
Finally got replacement calipers due to bad powder coating. Calipers are installed with bleeder at top. Bought bidirectional OBD scanner to cycle ABS motor. Something still isn't right. ABS motor energizes. Am I supposed to get fluid out of the bleeder screw when ABS motor is running. No fluid in bleed cup. I can pump pedal and get fluid in cup from all calipers. I'm getting C0201 code. Checked connection at ABS. Connection seems good Cleaned the two grounds I found on frame under driver's door. Do I need a new ABS motor?
