1 - 20 of 27 Posts
Push the mirror forwards (not folded in) and theres a hidden torx screw then a few little tabs under it that are supposed to slide out. Just a heads up, you're gonna break it. Seems like everybody does. I crazy glued the tabs back on then siliconed mine back up... if you're gonna open it, make sure you put in long life LEDs cause you won't wanna do it again.
2008 TBSS 3SS
I have a 2008 SS and the side mirror/underlighting/blinker is really only bright at night when turning, can you replace those bulbs to make the under mirror turn signals brighter?
Sure you could, they just don't reflect very well so I almost never notice mine during the day and I have a butt ton of LEDs in there.
moar cowbell
Trailblazer
turn on your hazards and stand behind your truck
they're plenty visible during the day... just not from the drivers seat
anyone have the part number for the lens? I broke my driverside lens trying to change the bulb and the problem wasnt even the bulb it was a loose connection inside the door after a speaker swap.:doh:
I will assume that no one makes these in a more clearer lense?
Probably dealer only item I'm guessing.
J
1 - 20 of 27 Posts
