1 - 5 of 5 Posts
So I know the Maggie guys have seen benefits, but is there any benefit from the upgrade on a pretty much stock TBSS( tune,CAI,UDP,Resonator delete)? I have one laying around that I was thinking of installing.
Anyone dyno this mod vs the stock TB?
Does it seem to run smoother?
We tested the LS2 and the LS7 TB back to back a few weeks ago. Speed wise, we did not get an accurate answer...HPTuners said the second run was started from a 2 mph roll, so keep that in mind. Knowing that, the times were virtually the same for both TB's, but the LS7 flowed a small percentage more.
I would say, unless you have a lot of other mods that require more air, the only change will be the throttle response. I believe a lot of other people have said the same thing.
1 - 5 of 5 Posts
