1 - 2 of 2 Posts
Im dropping in my LQ9 in a few weeks and want to tie up the loose ends of the conversion. Can anyone give me the list verbatim of what needs moving, sensor wise. Pictures and part numbers help.
I know the cam position sensor gets relocated to the rear of the valley cover.
Where does the crank and knock sensors go? Do I need an LS1/6 valley cover?
I appreciate it as always.
Discussion Starter · #2 ·
After beating my head against some walls..
The crank position sensor is the same, no change there
This thread shows the mounting solution for your LS2 knock sensors
http://ls1tech.com/forums/generatio...p-gen-iii-lq4-what-do-about-knock-sensor.html
Im still trying to find out why I cant, or I can, keep my cam position sensor on the crank cover. If it is to be relocated, it will be behind the valley cover in the rear. You will also have to use an LS1/6 valley cover. The only thing is there are 2 huge holes in them for Gen 3 knock sensor placement. Im looking into using say a flat Edelbrock or some other flat valley cover.
Anyone able to address the last couple questions?
1 - 2 of 2 Posts
