1 - 9 of 9 Posts
hey guys i took off out of my driveway normal and hit a small bump as i went from black top to pavement. right when i hit it it felt like the truck flew into nutral.
lost D and 3.
band? seal on acumulator ? piston?
or junk trans?
after reading in many places it seems as though it is the forward sprag assembly. has anybody a diagram or over replaced this before? PLEASE HELP....
Ahh trans check! Not good
2006 TBSS
My transmission was slipping from 1 to 2 and 2 to 3, and I eventually lost 2nd gear altogether. GM tried to fix it and ended up replacing the entire transmission 3 days before the 5 yr 100k mile warranty was up.
Hope you are still under warranty, or, better yet--tear it apart and build a monster!!!
mine has never slipped.. complete stock truck.. i change fluid at 30 and 60k same with transfer case. i dont beat it at all..
i hit a bump and BAM....felt like it was thrown into neutral.
gear selector still goes through all the gears.
any GM techs that can help a suggestion?
i have a scanner and everything to check anything but im not good with transmissions..
i think im going to drop the pan and see what i can see... nothing seems to be worn as it never had a slip problem or any indication of getting worn. Some thing flat out just had to break, could be as simple as a seal. but I dont know
1 - 9 of 9 Posts
