1 - 5 of 5 Posts
I have a 07 awd tbss . Last month while driving the stabilitrak light turned on so while driving I put it in neutral and fired it back up to see if the code would clear it did but after the restart I have no 3-4 gear . So it's been sitting for a while also noticed my passenger window ,lock and rap power is not working soI borrowed the solus scanner from work yesterday . Just got done scanning it I recently reset the computer by unplugging the battery so it had 0 current codes except for a u1000 . When I went into stored codes for engine it had like 25 codes and the transmission had about 10. It also won't communicate with the passenger door module and security module
I was thinking it had a bad tranny but now I just think it's in limp mode? I've checked all the fuses and changed the ignition. Switch and everything check out fine. What do I do?
1 - 5 of 5 Posts
