Since our trucks have a Walbro 255 in them stock, it's not an upgrade...
Yes! Stealth 340 is your best bet for quick and easy!I was talking to Joe (Leftcoast 32) about fueling and he had said the best bang for the buck would be Aeromotive's new pump. It not only flows more than the stock Walbro, its also a direct replacement. Prolly one of my next upgrades when the boost gets turned up.
http://www.summitracing.com/parts/AEI-11142/
He said there was a member running it with the magnavolt and lots of boost.....was it you? Whoever it was said they were having great results!Yea Aeromotive 340 is what I am using. After the tuning is about done should be able to tell how well its going to support my setup. Its running with my magnavolt too.
Well for the tbss its alot of boost lol.......but yea we are testing it out, I will post what we find out when the tuning is done. My setup is far more then what most will be, but so far I would say this pump is a good upgrade from our 255's. I am by far not the first to use this pump its been oit for a while. I am just seeing how far we can push the system essentially.He said there was a member running it with the magnavolt and lots of boost.....was it you? Whoever it was said they were having great results!
Yes, the top and bottom of the two are different because Walbro built the stock pump to GM's specs, but inside, it is exactly the same...I'm running the 340 as well. The stock pump may be the same as a Walbro 255 but its a different pump. I have both sitting on my bench.
