1 - 2 of 2 Posts
2006 SS Trailblazer
I am currently running LED's on my license plate light for over a year now with no issues. I recently noticed my driver side LED was out. So I figured it was burnt out. Luckily when I ordered from Jetttstream I ordered an extra set. When I went to install the new LED it also was not working. I turned them around because I know at times that's all you need and no luck also.
I then took out the LED on the passenger side and put in the old driver side LED and it worked fine. So I know now it's not the LED as they are both working fine. Anyone know what it may be? Are there individual fuses going to these lights?
'08 TrailblazerSS
Both license plate lights run off the same fuse, so if one side is working, its not a fuse. Pull the bulb out of the socket and check for power.
1 - 2 of 2 Posts
