1 - 20 of 50 Posts
Discussion Starter · #9 ·
ok see heres the thing. i want to have braided lines. Do your guys regular lines that come with the kit hold up fine??? im tryign to get a cooler to work behind the lower gril because i have the maggie intercooler in front and i dont want to put the trans cooler on top of that
· Some PCM of NC bolton's
Not the best photos but it sits in the middle of the radiator, NORCAL take a pic of the aera you'de want it (I know between the fog lights right?) and let me know how much room you'll have and i'll fig. something out for you. Also if you could snap a pic of the maggie intercooler and how wide it is.
The MagnaCharger Heat Exchanger is a full coverage unit. It covers the stock Radiator and A/C Condensor completely. You will have to go behind one of the Brake Ducts because there is plastic duct work that directs the airflow from the lower grill to the radiator too.
Heat Exchanger behind grill:
Lower Grill Duct to direct airflow to Radiator:
Discussion Starter · #14 ·
What ever one you get make sure it has a fan, when i'm stuck in traffic it goes up to 200, if I ride around anywhere from 20-80mph it's 160-180 w/ the outside temp between 85-100
Discussion Starter · #16 ·
well i live in san francisco max temp out here this year has been like 80 and even then my truck sits in the garage. Ive noticed with the LS1 fans in and with joes tuning and the new harness the trans temps stay a lot lower now.
1 - 20 of 50 Posts
