1 - 20 of 22 Posts
How about this question? on a stock bottomend. 243 cnc HC setup vs cnc HC l92 setup. how much more will the l92's make?
They may not make any more the a ported 243 if both setups use a stock truck manifold. A 360 cfm head and a 325 cfm head only flow as much as the 280 cfm manifold will allow. The L92 manifold is better then the stock TBSS manifold but not by a lot.
They may not make any more the a ported 243 if both setups use a stock truck manifold. A 360 cfm head and a 325 cfm head on flow as much as the 280 cfm manifold will allow.
x-2.... i was reading some info by patrick g //
useless to put a l92 head with top end, with a plastic manifold restricted at 280 cfm . .
its better to flow ur 243's at low and mid's and match a cam, and still have great street manners...
Unless your going with FI down the road, stick with what you got, and just add a cam.
so how much more power are we talking about? i was planning on getting a l92 heads intake cam package from pcm4less but not if its minimal gains.
stock heads/intake & aftermarket cam VS l92 heads/intake & same aftermarket cam
Depends on the cam. A good cam with stock heads could put you around 400-420 rwhp. Ported L92 heads and cam have been in the 445-450 rwhp range. I have seen a ported 243 head and cam combo go 445 rwhp too.
'07 awd
Can I put 2 sets of 243 heads on my truck since the flow numbers will be doubled and we all know 2 sets of 243's will flow more than 1 set of L92's?
Yeah, but you'll need three truck intake manifolds, at least.
They flow so well you get boost on an NA motor? That is some serious skill Matt! I bet they work well with the aluminum foil pushrods we made last year...
Yeah. I built my own strip about 1200 ft below sea level for internet hero testing. It's in a refigerated cave!
If the stock manifold only flows 280 cfm, how much more would it flow if it was ported and would it be worth it? Just curious!
You may want to read alittle futher cause the L92 intake is far superior to the stock intake.
As far as power ive had 2 different cams from pcmforless the n/a ground cam made 446 rwhp and the nitrous ground cam made 457 rwhp.
1 - 20 of 22 Posts
