1 - 8 of 8 Posts
now I gotta order my LS7 maf from greg and take the tubing over for PC and I should be good to go. Any install or other advice..I will also be relocating the washer tank and have Brandon tweek my tune when he comes to MI. Any advice or input is welcomed!
that some good advice...I havent even looked at what alvin put in the box but any tips af far as where to drill. I am sure he must say it somewhere in his install sheet??
TrailBlazer SS
You more or less should work from the throttle body outwards....
Do you have HPT? If you installed it I could get you close so you could drive it otherwise you won't be able to install it until Brandon get's here....when is he coming?
-Mike
Ant, take some pics along the way. I plan on doing this down the road. :coolthumb:
This intake is def. a must. I love mine. congrats!
To dress the hole, I just split a rubber hose and wrapped it around the opening.
No HPT mike but brandon should be here next weekend!
-Mike
nah pretty much only a small area to drill your hole, makes sense once you stick your head under there.
Cool just thought id ask!
I will do a write up bud, could be helpful to some!
I cant wait, I will try the rubber hose idea.
1 - 8 of 8 Posts
