1 - 20 of 28 Posts
From time to time the auto roll down feature on the front two windows do not work. Some days it works and other days you have to hold it down to roll the windows down completely.
Anyone else have this issue? Bad switches?
Truck is a 09 3SS.
Thanks in advance.
2008 Trailblazer SS
I am having the same issues too. It usually happens to be on very cold mornings. But I would like to know the cause as well.
Funny you mention that because I thought it only occurred on very cold mornings as well... until one day it was snowing pretty hard and I pressed the button to just crack the window open and it ended up opening all the way and blew snow in the car.
Bad contacts? Weird issue for a car that's still pretty new.
Yes... I know I'm short
'07 TBSS 2WD
Interesting... sometimes my driver door switches will lose power, and it is random. Then I have to cut the truck off, put the key on accessory and then it will sometimes work. Sometimes I have to cut it off and wait a minute or so then it will let me. Really wierd sometimes...
I have same problem acually have a video but can't post with my cell post when I get home
Sent from my MB501 using Tapatalk
For video go to youtube and type in tbss auto window failure ...
2008 AWD 3SS
Yeah mine did that too. They just replace my window regulator and motor (its one piece) under warranty for that issue.
Good info, thanks.
I have a list of things to address at the dealership... kind of sucks to have all these small issues on a truck w/ under 10K miles... :(
Good info, thanks.
I've heard of transmissions failing and spun main bearings at that mileage. Just sayin.:yay2:
With that siad I have an 07 SS and my window doesn't want to roll up when really cold it goes down in the cold no problem though.
My driver's side does that as well, my passenger's side doesn't do it, it just rolls up slower than hell.
2008 AWD 3SS
I've noticed my passenger side goes up hella slow since the new one they installed. I might make them replace that one also
2008 AWD 3SS
That would be the common problem. I didn't watch the video but that's what mine did
Discussion Starter #18
Brought the truck in today and the drivers side window issue was because of a bad switch. The part was replaced with Part #25867000.
So far the drivers window works as it should. The passenger side is working fine at the moment. If it acts up I'll ask them to replace that side as well.
2008 AWD 3SS
They are doing my passenger side Monday. It's 100% slower then my driver side now
i have had my regulators replaced 2x now, the passenger has had a total of 3 new ones in it and the drivers has had 2! And I'm currently having the same issue now as well (again)
1 - 20 of 28 Posts
