Running a catch can will keep the oil out of your intake manifold. Also, if you change injectors you will need a tune.does anyone have any opinions on the condition of this intake manifold. Has anyone else had issue with excess oil build up inside? I was thinking of purchasing new intake, fuel rail and throttle body as a single unit, however, I've only found 50 lbs injectors and I don't think the factory injectors are that high. If I install the higher capacity injectors, will I need to tune the ecm? Anyone post on this forum?
