So I know that heat is one of the main killers of automatic transmissions and a lot of threads here seem to indicate that the 4L70 in stock form may not have been the best choice to put behind the 6.0. Ever since I put an Aeroforce gauge in to monitor my temps they creep up to the 200 degree range after driving for awhile.
I talked to my dealer about it and they're like "oh, yeah, that's perfectly normal...no problem." They brush it off since the trans fluid is running through the radiator and life is good...according to them.
I asked about what would happen if I installed a PCMforless cooler with a fan to lower the temps. They started blathering about flow rates being off and that it would void my warranty. I asked them straight up whether or not heat is bad for transmissions and they said yes. I asked if lowering temps is a good idea for trans life and again they said yes. I asked if I should install a different cooler to drop the temps and they said to not worry about it unless it gets to 250 or so. They stated that the system was designed to run that way.
Anyone else run into this? Seems crappy that if YOU try to do something to prevent a failure, they'll blame it on you and void your warranty. I'm thinking about getting the cooler and if I run into trouble, pulling it back out before I go to a dealer for service.
