1 - 20 of 42 Posts
2007 TrailblazerSS
Guys,
IF I keep my blower and decide to put it on, which is like 5% chance, should I get a bigger radiator or will the stock one still be ok? I'll be pushing MAYBE 9 psi.
TrailBlazer SS AWD
I have the stock radiator with the LS1 eFans, 12# of boost, no cooling issues at all.
2007 TrailblazerSS
Just what I wanted to hear, and one from hellish temps too. Thanks for the quick replies. I'm really itching to throw it on now that no one seems to want it.
2006 Red Jewel AWD
I run my truck in 100-degree temps in the summer with no cooling issues, truck runs at 184-192 all day long...But I don't have the heat exchangers in front of the radiator.
You should only need to consider an upgraded radiator if you had a BIG heat exchanger(s) or a thick front mount intercooler in front of your radiator in the grille area although living in Houston doesn't help your case that's for sure.
so...... when are you putting it on? ill b in Paraland TX around christmas!
2007 TrailblazerSS
Discussion Starter · #10 ·
Alright guys, is there a place where I can figure out what belts I need to run with the different pulleys and 10% OD crank pulley? I'd like to keep it max 8 psi until I go forged, so does anyone know what pulley I need to use? Can't believe this shit is actually getting done.
If you don't want it I'll take it off your hands :cheers1:
2007 TrailblazerSS
Discussion Starter · #13 ·
3.2 or 3.1!
Joe is the man to tell you! Why not just keep the stock balancer on for now?
Came with an 8 rib setup, so I went ahead and bought the 10% OD not knowing I could just run a 6 rib belt... yeah, I'm a complete noob when it comes to blowers (this is my first "fast" vehicle ever). I tried to get it from Joe, but couldn't get a response, so I went through Brandon @ 262. I'll dig out those pulleys tonight to make sure I have the right ones.
2wd Turbo
You can still run all the 8 rib stuff and run a stock 6 rib balancer with a 6 rib belt. Then a 3.0 should be just about right... when its time for more, slap that 10% OD balancer on!:coolthumb:
2007 TrailblazerSS
Discussion Starter · #15 ·
Oh HELL no!!!! I bought that thing and it's PURDY. It's DEFINITELY going on there. If this shit sits in my garage/in my room any longer, I'm destroying it with a sledge. It'll all be on come November :D
2007 TrailblazerSS
Discussion Starter · #16 ·
Talked to Joe, said to run a 2.9 - 3.0 on it since a 2.7 gave 10psi for him on an MP112. Thanks Joe for the valley cover and the info on your intake. Looks like I'll be going with the LS7 MAF and just need to drill a hole in my fender. Whoo-hoo!
2007 TrailblazerSS
Discussion Starter · #18 ·
Nov. 5th if I have all the parts in time (I should be gtg now, but I need to pull everything out and make sure.) Anyone know what it should run full weight on slicks?
2007 TrailblazerSS
Discussion Starter · #20 ·
All right, like I've said before, I'm new to all this. I'll be posting pictures of EVERYTHING I have tonight, with measurements of the pulleys. If I'm missing anything other than the valley pan, can you guys let me know?
1 - 20 of 42 Posts
