81 - 93 of 93 Posts
Just a noob
Don't mean to beat a dead horse, but I was just quoted $700 friggin dollars! I can't pay that. I won't pay it! Can anyone help please. When I turn on the air it comes out cold like it should on the drivers side upper vents, but heat comes out on the passenger side upper vents and I mean super hot! Someone please help
It's not hard to do. Just takes some time and simple tools. My thought is a few hours of my time is better than paying someone $700. Hell even if it was only $50 I'd still do it myself that way I know it was put back together correctly
I gave it a try, but I'm too large to fit under the dash. Need to hire a small person to help me. If you know of anyone send them my way please.
2008 AWD 3SS
I am going to try to do this on my truck soon. I didn't see where anyone ever posted the write up in the post. Any one have it that they can send it to me?
[email protected]
2007TrailblazerSS
if you pull the gas pedal out it frees up tons of room. whole fix took me 30 minutes
I'm having this same issue i think. Clicking noise everytime I turn the truck on and the air is always coming out the dash vents and gets super hot.
9-7x Aero
When I change the mode from face to floor the air stops blowing on the face, but barely comes out of the floor vents. Just a tiny it of air. This wouldn’t be the mode actuator, would it?
Not sure if it’s relevant, but the rear floor vents blow at full force though.
'08 Silver TBSS
The rear air has separate actuators independent to the front.
Sounds like your mode actuator is not switching fully to floor in the front.
06 TBSS
No control
I have the same problem, I heard there could be more than one actuator,
is that true? How do I know which one to replace?
Saab 9-7x Aero
I am having same issue after changing out my HVAC climate control for a less beat up looking one. I replaced old one and same issue persist. I hooked up Snap on scanner and i was getting a mode door code, so i replaced mode door actuator. Now i have no code but still no air coming from vents. I have tried calibrating it by either removing battery, removing hvac fuse b, or via scanner and still doesn't work. I do here all the actuators doing there self tests when i turn vehicle on but still know luck. Can someone please send me schematic, and calibration routine to [email protected].
81 - 93 of 93 Posts
