1 - 4 of 4 Posts
I have a 07TBSS 2WD with 180K. I am getting a buzz in the steering wheel and think it is in need of a hub replacement based on this site.
** Is that only the bearings?
** Is it difficult?
** Should I do both sides?
The truck is stock except I replaced the airbags with springs.
Thanks
** Is it difficult?
Thanks
Check out the MOOG hubs. Replaces everything involved with the wheel hubs. Yes, do both sides at same time. It is an easy job.
2008 TBSS Super Charged
06 trailblazer ss
I use the acdelco original equipment ones from rock auto. They have a lifetime warranty and are good quality for just a little more than the moog ones. Moog is also good quality, but have a shorter warranty. If you can do brakes you should be able to do wheel hubs. I would also do both. Only special tool required is a 36mm socket.
1 - 4 of 4 Posts
