1 - 20 of 37 Posts
Senior Towmaster
2007 TrailblazerSS
Here is the guide to install a Ron Davis radiator from Simple Engineering. This is the complete guide with many suggestions from Mike. Mainly to treat the radiator/fan/shroud as a complete assembly for ease of handling.
Senior Towmaster
2007 TrailblazerSS
Step 2
Raise vehicle and support on jack stand(s)
Remove rock guard from frame for working hose clearance.
Remove lower radiator hose and drain coolant into bucket.
Senior Towmaster
2007 TrailblazerSS
Senior Towmaster
2007 TrailblazerSS
Step 18
Unhook the two rubber flaps from the shroud. Passenger side top flap hook through the air box area with needle nose pliers. The other hooks come off from the bottom for the best reach.
(Disconnect trans cooler lines from lower shroud if you were not able to disconnect them at the loop.)
1 - 20 of 37 Posts
