21 - 37 of 37 Posts
Going to use this how to for my ignition switch
subscribed for future problems. Good info
· Mattmikemark
2006 Trailblazer SS
My TBSS is a salvage and to start you must insert the key all but about a 1/4 of an inch from being fully "flush" for the lock cylinder to turn. Does anyone know if you just buy a new lock cylinder with key that it will work with all the other original parts in the ignition?
Thanks in advance.
· Registered
07 Silver TBSS
I just did this last week using post #15 for guidance. You have to finagle the bottom plastic cover off the steering column b/c of the lip, but overall great instructions. I did not remove the steering wheel, key cylinder, or airbag (kept clear of it), but I definitely disco'd the battery.
Yes, your auto parts store should be able to get you the key cylinder for a reasonable price. Go w/ the better brand if they have options. I went w/ the Borg Warner ignition switch for mine, from O'Reilly Auto.
2007 AWD - 3SS TBSS
I just did this last week using post #15 for guidance. You have to finagle the bottom plastic cover off the steering column b/c of the lip, but overall great instructions. I did not remove the steering wheel, key cylinder, or airbag (kept clear of it), but I definitely disco'd the battery....
:coolthumb:
· Registered
Had mine not start this morning too. Dropped the kids off at daycare, got in the truck, turned the key and nothing. No noise, no clicking, I mean nothing. Everything else on the truck works fine. I waited a while and finally got the truck to start just as I was on the phone with a tow truck. Now it seems to start everytime. Not sure what's wrong, so I took it to the dealer for a diagnosis. I'll let you guys know what they say.
Is what I described a symptom of a bad ignition switch?
2007 AWD 3SS
Mine did the same thing this past Wednesday. Pulled it in the garage the evening prior - got in it the next morning and it wouldn't start - checked the battery output and all was good. It didn't make a sound when turning the key to engage the starter - everything else seemed normal. Had it towed into the dealer - still under factory 3/36. They found it to be the Engine Wiring Harness Junction Box - they called it the ignition relay, but they told me they usually just replace the whole junction box if something shorts out or is problematic. I have attached a scan of the warranty work -
Initially I thought it was the ignition switch.
I was working on the tune on an 06 once and it seemed like the computer died, but the real culprit was a bad fuse connector in this underhood junction fuse box. All it took was a few tweaks with a small screwdriver and everything was working great again...just took a while to figure it out.
2007 AWD 3SS
Funny...mine did the same thing yesterday after dropping the kid off at daycare. Finally got it started, took it home, switched cars and bought a new ignition switch. Will be changing it this morning.
2007 AWD 3SS
Thanks in advance.
If the key fits the door perfectly, then just have the cylinder matched to the key.
If the key also fits sloppy in the door, then buy a new set for the ignition and door, just because that would mean someone else owns the 'right' key (as in, maybe the guy who had it before it was repo'd).
2007 AWD 3SS
Damn..that was easy. From the time I posted before this post (9:55AM), I took the cover off, pulled the old switch, took it apart to examine, put the new switch in, replaced the cover and cleaned the dash... and had a cup of coffee ...and finally got around to posting this (10:45 now).
Oh, and it fixed the problem.
· Registered
2007 Trailblazer ss
This will also be a problem if you have an aftermarket remote start system, i just had a crank no start issue with the same ignition switch code p1682. I got a new switch and insatlled it and the same issue was happening, i followed the wiring down to the remote start wiring and box, moved stuff around tried it and it started but with the same running rough issue that others had complained about so now i am gling to take the whole thing out and try that.
· Registered
My truck lately will randomly not start. It has left my kid stuck a few times, but then I show up and I can start it no issue. Figured I would try the ignition switch since it has 160k. Glad I found this thread. It was quick and easy, hope it solves the problem.
21 - 37 of 37 Posts
