1 - 20 of 32 Posts
· The Worlds my Playground
I know this should be a hot topic sooner or later, so Ill start with a few pics from my install. Heres the parts that went in during the cam change.
Crane Cam... Vinci Grind 056 * -2 Retard
1.7 Yella Terra rollers
Comp pushrods
U/D pulley
Double row timing chain
ADM intake / MAF
2004 vette efans
PCM4Less fan harness
High flow oil pump
3" custom magnaflow mandrel exhaust
Stock heads
Stock manifolds
Stock springs (have patriot dual golds going on custom heads; some day)
____________________________________________________
This helped me out when I did mine. People had qouted me anywhere from 650 to 800 bucks... NO WAY! I bought two primary tools to do this, the rest I had. If you are mechanically inclined, YOU CAN DO IT.
1. Remove the rockers and pushrods.
2. Spin the old cam over several times. This gets the lifters in the up position.
3. Insert the two 5/16" rods.
4. Now you can remove the old cam and insert the new cam.
Tools-
Thunder Racing: JPR LS1 Cam Installation Tool $84.99
Tims Cylinder Air Fill as well as the Spring Tool - Shipped $50
Resource- * UPDATED *
http://www.tbssowners.com/docs/Camshaft%20Replacement.pdf
http://www.tbssowners.com/docs/tbss_Torque_specs.pdf
http://www.tbssowners.com/docs/TBSS_6L_Engine_Specs.pdf
http://forums.corvetteforum.com/show...allation+ca m
http://www.ls1tech.com/forums/showth...&page=14&pp=20
· Registered
2006 TBSS
Wish I did my own.. Shop that did mine removed the heads to do the cam swap.. Taking extra precuations they told me.. I'm still a little bitter about that whole experience. You want something done right, do it yourself. I think Napolean was the first one to say that.
self-gratification : the act of satisfying your own desires and giving yourself pleasure.:D
Did you need to evac your AC system? It looks like yes, but I was hoping they would push out of the way, like on the CTS-v's.
2003 ZO6
evac
i evaced my a/c system and removed everything that i could so i could have more room made it alot easier im sure.i feel alot better about doing it myself especially since no extra bolts (atleast the ones that should have been left over)and she started up right away it actually went back together well,i would do it again if i had to.oh and you have to take out the radiator/condenser to get the cam out so yes evac the system.
Ditto... Purged the a/c, that was the only real thing that sucked. Took it to the dealer and they were not happy to re-fill, but they did.
Yes, mine started up as well, just used the V2 to adjust the idle rpm's.
· Registered
2006 TBSS
What are your cam specs?
Discussion Starter · #11 · (Edited)
wow.How long did that take?
Im wanting to say about 12 hours total.
Gotta have beer breaks, picture time, and more beer along with the war stories from the neighbors.
Started saturday morning, finished up on sunday. Overall, it was not all that bad, fairly easy if your mechanicly inclined.
· Registered
I did my own on my 00 SS Camaro. I dropped a lifter since it was a high mileage motor and when I spun the cam they all locked up but when I went to slide the cam in one fell. I didn't use the rods that help hold the lifters. I used magnets and my buddy wasn't watching and let one fall. Needless to say I had to pull a head, drop the oil pan and the windage tray. WHat was a 8-10 hour job turned into a 24 hour job. But on a low mileage motor I wouldn't be scared to do it again. In fact I will be doing my own cam install when I get ready to do it.
· Registered
06 TBSS 2WD
The LS2's come with the heavy duty chain already. All I did on mine was pull the timing gear off. Didn't remove the oil pump at all. Reused the water pump gaskets as well. I swapped heads so I pulled the lifters out. This was the first lsx head/cam swap for me or brother-in-law...started Sat morning and running by 5PM with about a 2.5 break in between.
Discussion Starter · #16 ·
That is more of a Cliff Notes version than a How-To. If anything, you just scared people from attempting to do it on their own.
See Resources.... If thats not enough info, then your right, DO NOT ATTEMPT TO DO IT YOURSELF!
My point was to show you (with some pics and RESOURCES) what it will look like when ripped apart...
· Registered
How do you like the Vinci #56 grind, I was looking at either that or the xxx from Vinci since both have the 115lsa and I was eventually wanting to go with a blower. Is it pretty streetable? power gains?
Discussion Starter · #18 ·
I haven't had it on a dyno yet, but will possibly next weekend after the header/exhaust install.. I would have to say, it deff made a difference by the SOP factor.. It feels much stronger than it did from the factory..
Read what happened with this cam on spay and then with a s/c:
http://www.vetteweb.com/tech/vemp_0702_ls2_crate_motor/index.html
· Registered
Wow!....that is quite a jump with cam, intake, and tb. These LS2s really seem to respond well to cams. Those are some nice number with the s/c too, I wish ATI would hurry up with the kit for us, guess they are having trouble making it fit. Thanks for the link....and keep us posted on the results if you dont mind!
1 - 20 of 32 Posts
