1 - 20 of 75 Posts
I have been studying time slips and build threads. I am having trouble narrowing down a ballpark figure to shoot for. I have an AWD stock weight. My goal is to run mid 11's, atleast 11.5's. The tracks that I would most often run at are at most 300 feet above sea level and air temps will vary widely with the seasons. I am in the early phases of planning a build and am trying to be as realistic as possible about what that will take. I would like to hear average expectations as I know that some folks have had freakish results which I do not expect to happen for me. Thanks in advance for your help.
08 Black Granite
6xx
Me>Matt
not sure how much power steve (evilss2006) made but he did 11.5 with cam, d1, ptb3600, and the typical bolt ons full weight on 20s
im at 11.8 with 465 475hp
So your saying it only takes an extra 10-20 hp for the guys with awd?
I thought awd where like 500 lbs heavier?
this
maybe a little less
then again, remember all dyno's are different....
He did say atleast 11.50. I figured 550-585 would put him there pretty much every pass.
Yea but aren't u 2wd??
hes awd with a maggie. Thing is he needs to figure how much more hp it will take to drop those other 3-4 tenths. Theres a pretty good jump in hp to jump from 11.8x to 11.5x and to consistly run 11.5x.
How much tq is the maggie truck making at the wheels? Ill bet its in the 520-530 range with 480 rwhp.
not sure what my tq numbers are. gonna be making anouther trip to ttp sune so ill get them then
i went from 12.4 to 11.8 with intake and meth. didnt gain alota hp
same track 12.4 was in october. 11.8 was this month. hes running alot more timeing but a pretty mild tune for dd. next tunes gonna be very aggressive
2006 Red Jewel AWD
With my setup prior, I was on the ragged edge, 18 degrees of timing, meth (~22% of my fuel needs), cam, stock heads, stock bottom, as Drew stated prior. If I knocked my truck down to 16 degrees of timing for the street, my ringland probably wouldn't have popped and I wouldn't have lost the motor.
Remember, I ran [email protected] with a 1.67 60ft. so I was hauling the mail in the back end, most 11.50 runs are 116-118mph. I also did this at 5,200ft. DA's so your 300ft. puts you at an advantage based on power needed to make a comparable pass.
You also added an 8 rib with 10 over crank pulley. Same track I would say DA was similar. I was there for both runs.
For op this my goal as well and have been working towards it for a year. Do you plan on going FI or motor + spray ?
Alot more timing = power
What would you guess hp was when you ran 11.52?
1 - 20 of 75 Posts
