1 - 20 of 21 Posts
Just plugged in a hid kit... Worked perfectly. Then turned the car off then back on heard a click and now no more hids.... No light ....nada. Help please
stupid white guy
if you heard a pop, it could have been a fuse or relay or something. Check the obvious stuff first. Turn on lights and use test light to find out if you have power or not
Mine was a fuse. Had to check every single damn one of them to find it too. :doh:
Did u find out what caused the fuse to pop?
I actually tried a different buillb altogether non hid and it worked ... Could both hids have gone out
Mattmikemark
2006 Trailblazer SS
Sounds like a ballast problem... Where did you get your HID's?
I got mine from Jetttstream and after installation the low beams flickered BADLY. I sent him a video of it and he could tell right away that it was the bulb. Said it could only be a ballast if I had lost power completely (which sounds like your problem.)
Did you buy more than 1 kit? If so, replace the ballast with one from the fog light? :dunno:
Fuses burnt a 15 and a 20 should I use a 30
Just burnt 2 30 fuses
Anyone
Discussion Starter #12
Replaced the ballast and put a 30 fuse on it now to see
you have a ballast problem. jetstreems hids are way over priced. go to ddm tuning u can get high's low's and fogs for about 100 bucks shipped to your door. within a week if they have in stock if not can be month or so.
eBay baby!! And Luis. Your truck just hates you...
correction u have a short if there blowing fuses 20 and 30 should not need more than 30 even 20... and the flickering is a power problem u need a wiring harness for the flickering problem the ballast is taking to much power to light the bulb corectly and the car is confused just need simple wire harness 15$ at ddm tuning..
finally someone listens to me lol
Mattmikemark
2006 Trailblazer SS
I put in a new bulb and the flickering went away :dunno:
Discussion Starter #19
I changed the ballast and get now flickering they are working great. Also unplugged and re-plugged everything... It's a beauty now
Sent from my iPhone using Taptalk
Discussion Starter #20
1 - 20 of 21 Posts
