1 - 11 of 11 Posts
Guys,
Have anyone ever had this issue? I'm all stock, throttle body removed and clean, and spark plugs replaced. What else I'm I missing?
Thanks
Is your check engine light on? Mine was doing the same thing and had the CEL on, the code was for a leak in the evap system. I changed the solenoid beside the drivers side of the intake and the canister on the side of the fuel tank, both easy jobs as long as you are careful with the clips. Cleared the code and it is like a new truck. A vacuum leak like that will lean out the AFR and the truck will feel like a turd, especially at low rpm.
- Flash
08 Black Granite
Look for a cracked plug.
Clean MAF and replace plugs, ohm and inspect wires.
08 trailblazer SS
Is this the normal drive by wire hesitation, hit the gas and theirs a second or two delay before you feel a response.
Reactions: LeftoverJay
07 TrailblazerSS awd
My truck was real bad with that. I did boltons and tune it was night and day difference.
Sent from my SM-G900P using Tapatalk
Sole go fast parts and a tune will take care of your problem immediately.:biggrin2:
1 - 11 of 11 Posts
