1 - 5 of 5 Posts
I installed HID kit about 6 months ago all of a sudden they went out so I unhooked the ballast and put my meter on the factory harness I am only getting 1.0 v I checked all my fuses and they are fine.
What could be causing this problem? I also put in the factory bulb as well just in case with no success.
any help would be greatly appreciated, Mike
I am driving around with my high beams now at night lol
Death Machine
swap your headlight relay with your fan relay.. and see if they come on..
If they do then swap relays back and pick one up at Autozone or the like..
I see what you did there
06 TBSS
This happened to me already. Do your high beams work? Horrible setup.
BPT_TBSS
TBSS 3SS
I had the same problem I could only find the correct part at NAPPA($41) or the dealer(arm/leg), it is the black solid state relay labeled HDR on the fuse block diagram under the cover.
08s do not have the second relay to swap.
This appears to be fairly common, at least it is easy to fix.
1 - 5 of 5 Posts
