Roughly you got a figure for monies spent not including labor and time obvisiously.
To start off with, there is a lot of potentional for problems with mail order tunes. Or at least the 11 I have tried. This includes ADM, Westers(from tune time) and Vector.
This could be caused by your truck, available fuel or some wierd mod you have done. I think all mail order tunes should be logged. DashHawk, HPtuners, EFIlive, etc. This way you can give your tuner feedback if needed.
An issue with Vector and Westers is their tune is locked. So if you need a slight change made, you have to send the modules back and let them make the edits. With PCMforless and ADM if you have Hptuners/EfiLive they can read your logs, make changes and send you an adjusted file.
That said, if I was going to do it over again I would still buy HPtuners. And even though I have not used PCMforless, I would. I like what he has to say and appreciate his helpful attitude and how he wont trash other vendors. Hpptuners (basic version) is $499 and I think Alvin at PCMforless charges $150 for a e-mailed tune.
I have a Vector
intake now, but the IEATSRT8 intake is a better design and functionally the same for less money. $246 plus $8.00 for optional seal. ADM has an awesome intake with a larger MAF. It requires special tuning and on a mild motor, I dont feel it has any gains over the IEATSRT8 or Vector. Its very cool.
HSRK kit. I wouldnt waste my money. The unit I bought from Vector does not work. I have scan logs comparing it to the stock IAT and it just doesnt help as advertised.
The
E-fans I have are pricey as ADM was the first kit out. They are awesome, but you can buy a plug and play kit from PCMforless, Vector or Tune time now and use LS1 fans. You will have to ask for price, but its going to be a lot less than my ADM kit.
Ported and polished LS7
throttle body. There was just a group buy on these for $260 for the ported version. On a mild motor this is just bling bling. No gains as far as I am concerned.
Underdrive pulley with bolt, seal and belts was $300.
My
Stall converter from Yank was $895.
Trans Cooler from PCMforless. This kit IS the best.$250. (must have for a stall)
Misc
transmission parts including deep pan, servos and beefier internals was about $900
My current Vector tune runs great. No issues at all. But I had to send them my logs and send it back a couple times (the first being a ordering mistake on my part). Vector is known for delivery problems. For whatever reason they are always out of stock.
