Hello all, glad to be here. I am the owner of a white 2006 TBSS RWD that I picked up a few months ago. As of this point the truck is torn down and I am building the engine and putting in a built trans. I will be doing a video series for the entire build and hope to share any issues/fixes I ran into in order to help anyone else doing this. It's important to note that this build is somewhat of a budget build so hopefully others out there can duplicate. The goal is 800rwhp built by yours truly- daily driven.
Quick build sheet:
6.0 Lq4 Iron block, stock 243 heads
Forged Pistons/Rods/LS2 crank
TSP 228/232 cam/pushrods, beehive springs, Ls7 lifters, trunnion upgrade
Cast manifolds/crossover pipe, VSR 7875 T4 Billet (1.25ar)
Performabuilt 4L70e transmission, FTI converter with 3200 stall, standalone trans cooler
Fuel system will be done once the truck is running, I will be running a dual pump setup with 120lbs injectors- E85
I'll keep you guys posted on the progress, should be done in a few weeks!! Pic when I bought the truck:
Quick build sheet:
