1 - 4 of 4 Posts
Moderator
06 TrailblazerSS 2wd
Do yall have a headlight resurfacing kit? If not yall should put a kit together to polish out hazed over headlights and seal them up afterwords. I have the portacable polisher, It would be nice to have a kit to use a polisher like that because the kits on the market are hand polishing kits and will wear out your arm lol.
Mattmikemark
2006 Trailblazer SS
I've had good luck using their paint polishes with microfiber pads, followed by their panel sealant. If you watch their vids it says to seal your headlights with paint sealant. :2cents:
Headlight restoration is a lot like paint restoration. A machine, pads and polish will get the job done if its only lightly hazy. If they're really bad you may want to sand them first to save time.
After you fix them keep them protected with a sealant as mrinken suggested. There are dedicated UV protectants for headlamps out there, but they usually require specialty lighting to harden and cure.
1 - 4 of 4 Posts
