thanks to spx7 for the info. i ended up getting the coilovers and the 150 lb spring. Bolted it right up and only thing i used 2 washers on the inside of upper mount to push them out a tad because didnt want it that close to the frame.
I had it on the hardest setting dropped the truck almost didnt move lol. I tigtened the springs so it just has tension when tire is in the air and then set the shock to the softest setting and i should start testing it out at the end of the week. Ill prob drive on softest setting then middle then the hardest on the shock.
If you guys decide to get the shock the DR8855P is the one id go with. 19.5 extended because the one i got (DR7855P) I feel will be to short for the guys that arent lowered as low as me and tire will come off the ground possibly on steep inclines.
The 150 lb spring will be good with the air bags we have if you want to take the air bags out completly like spx7 is then id get the higest spring rate you can get. 350 or 375 if im not mistaken.
now the 150 rate springs are for 1250-1450 pounds. I know not all the weight is on them because i have the air bags but ill see if its that stiff for the ride and if it is ill step down. the 105 spring rate springs are for 1000-1100 which is also a good rate. oh well trial and error thing
