1 - 6 of 6 Posts
Probably a dumb question but can someone tell me how the grill emblem comes off, screws or tape? Thanks:dunno:
Midgets with hammers
'06 TBSS AWD
The bowtie?
Open your hood and use a pair of pliers to help the top clips that hold the grille into the headlight support. Then reach down and cup your hands around the center bar at the outer sides and grip your fingers in the honeycomb. Now pull. Hard. It'll sound like it's breaking but it's not. Then look on the back for the two stamp nuts (10MM) and remove them and the bowtie will fall out.
murdered tbSS
Take the main grille off. Like 6-8 tabs. (They just snap in). And after you have taken grille off there are 2 screws that hold the bow tie on.
needs moar powa
Taking off your grill for the first time is alittle scary, but it just clips in there. Start at the bottom and the headlight piece and pull -
Then 2- 10mm bolts hold the emblem in place.
1 - 6 of 6 Posts
