1 - 19 of 19 Posts
well got it in the mail today ill see how it works out. post pics of it tomm.
the bar should be stock size but its a solid bar not hallow and comes with new mounts. Ill post it up in about a hour or 2
SS TrailBlaze 06
Was it a easy install? What did it involve? Thanks
Discussion Starter · #9 ·
since my truck is down i pulled it out and installed it on my buddys 07 today. He said right away he felt a difference. The ride feels much better on the twisties by his house. Hes coming back tonight so i can take it out and give him is stock one.
SS TrailBlaze 06
How much does the stock sway bar weigh? I need to know before I pull mine for the track only to take weight off the front & let is lift more on launch. Thanks
07 AWD TBSS 3SS
Just ordered my Addco Sway bar Sunday. Should be here next week. Tell you how if feels after instillation. I'm all for less body roll. :cheers1:
· Registered
'06 TBSS
You won't be disappointed. I got in on the GB when they had it going....I bought the F/R combo. Best $250 I've spent on this truck.
· Registered
'06 TBSS
Does anybody have the installation instructions for the front and rear kit that they can scan and post? I would like to see exactly what i would be getting myself into.
Hmm...I'll have to see if I saved mine. I think I threw them out....
If you can use a socket wrench you can install the sway bars.
· Founding Member!
2012 Ram 1500
I do not think I have them anymore, but if I remember correctly, it is just 4 bolts in the rear to remove the bar (2 on the bar and 2 for the supports). The front I do not remember how many bolts, I think 4, but I do know that it is easier if your remove a wheel, because you have to slide the bar out to the side to remove it
· Registered
'06 TBSS
Rear:
2 bolts on the bar
1 bolt on each bushing bracket
Front:
2 bolts on the bar
2 bolts on each bushing bracket
Remember to grease the bushings.
Tip for taking the front out:
Take passenger side tire off
turn the wheel all the way clock wise
As you pull it out on the passenger's side turn it clockwise or counterclock wise i forgot which way and it will come right out. You have to completly turn it to make it come out though.
1 - 19 of 19 Posts
