If I did it again I would go with headers and a single out or true duals.if you are going to waste 1000 on a single in/dual outlet muffler dont do it.
a true dual set up from headers back with muffler/pipes and tips will be 500 at most then a shop can weld it up for a couple of hundred bucks. FLow much better.
I'm not so sure I agree with you. Here is a video from WBH SS. http://s2.photobucket.com/albums/y3/1bernie1/?action=view¤t=e946eac5.flvYou will not see any HP gains with just cat back but the tone of the exhaust will be a lot better and a little louder. In my opinion i would go with the duals vs the single.
Honestly I cant see spending 1000 bucks on just a cat back set up especially when its a fake dual set up. Here goes my long tubes with a magnaflow 3 inch custom cat back set up. Total cost for headers and exhaust less than 950 bucks.
ok 93 shipped from ebay for muffler
So total cost like 300 bucks then add brackets which a shop will have like 20 more. labor to weld it all up 200-300 at most. So its up to you man. Even a single 3 inch set up would be better flow than cutting it up into dual 2.5 outlets from a singel 3 inch inlet.
125 shipped? how loud is that exhaust inside the truck and is it a straight bolt up or would i need to take it to a shop?Honestly I cant see spending 1000 bucks on just a cat back set up especially when its a fake dual set up. Here goes my long tubes with a magnaflow 3 inch custom cat back set up. Total cost for headers and exhaust less than 950 bucks. (btw i have for sale the 3 inch cat back set up in the below vid for 125 bucks) BTW this is a single inlet/outlet magnaflow and just listen to the sound
