1 - 4 of 4 Posts
· Registered
06 tbss
what up guys....need some help here my 1-2 gear is slipping and i think u can see it here
http://s167.photobucket.com/albums/u157/ls2beasst/?action=view&current=somerolls005.flv
what would it be i have my gears shifting at 6500 but i dont think thats it because my other shift just fine at regular driving it wont slip but wot it does..trans is new i added shift kit and new clutches and band....think maybe adding a 2 gear billet super holder servo will work...? i have a corvette servo but it sucks....cant feel it for shit ! im gonna go to autozone and buy a LUCAS TRANS OIL FOR SLIPPIGAGE supposly it works great and stops that !
what do u guys think.....i have royal purple in the trans !
SS TrailBlaze 06
Save your money your second gear band is toast. Smell the oil from the tranny dip stick you will smell a slight burnt smell. You will also find the other disc to have some glazing. The drum the band goes around can be turned if you don't wait to long. Billet servo's are the best to use also Transgo shift kit & a tranny shop knows a few more tricks & don't use all the shift kit pieces. The rod length on the servo's is not stock so I discourage do-it yourself if you don't have a good tranny guy by your side. You live close to Phoenix trans let them fix you up for less the $2000.00 including a 2800 to 3000 stall then let them know if you want to shift hard. If you ask for hard shifts it will lay down second gear scratch. Love mine now & befor I had a sluggish 1-2 shift & yah the second gear band was toast. Metal to Metal also no codes. LOL
2007 AWD 3SS
If the fluid is not burnt, you can fix or reduce by increasing pressure by either of these two ways:
1. With a programmer, set the 1-2 shift pressures to ~12 PSI above stock.
2. Without a programmer, drop the trans pan, adjust the electric pressure control solenoid screw about 1/8-1/4 turn in. It's on the solenoid itself and you use an allen wrench. You will have to remove one of the accumulators to access the screw, that's easy, just a few bolts.
Of course you should realize if the fluid is burnt then increasing pressure will only, mask the symptom.
1 - 4 of 4 Posts
