1 - 8 of 8 Posts
So I am still trying to figure out my electrical problem. I removed the fuse block under the hood to see if I have a broken trace or something. I'm not sure how to separate the two pieces. Do I need to drill out the 4 bolt holes from the bottom or what?
2006 white 2wd
When we first took ours apart we didn't see a break in the wire either. It took hours and a few sets of rested eyes to finally find it. We used a small pic to gently lift each spot, and that was what found it. Hope you resolved your issue.
1 - 8 of 8 Posts
